(1) Dual-Band WiFi
- The BR1 MK2 router supports both 2.4GHz and 5Ghz frequencies simultaneously, which provides more flexibility and reduces interference.
- BR1 Classic supports 2.4GHz only.
(2) LAN Port
- The BR1 MK2 features 1x GE Port.
- The BR1 Classic comes equipped with 2x FE Ports.
(3) Dimensions
- The smaller form factor of the BR1 Classic makes it suitable for even the smallest of spaces.
