(1) Indoor/Outdoor Deployment
- The BR1 Classic is certified for tough and train deployment. (Indoor / Industrial environment)
- The BR1 IP67 is compact and features an IP67-rated enclosure that is fully sealed against water immersion, dust, and inclement weather. (Outdoor environment)
(2) Antenna
- The BR1 Classic comes bundled with a standardized antenna and is also compatible with other antennas based on your deployment.
- The BR1 IP67 is embedded with cellular and GPS antenna, ideally deploys at the optimal signal spot.
(3) Power Input
- The BR1 Classic is equipped with a power port for secure power installation in vehicles and other locations.
- The BR1 IP67 supports PoE input which cuts down on cabling and simplifies deployments.
