Our ISP upgraded all Fiber Broadband to 1Gbps Download and 500Mbps Upload and yet BPL-210 router throughput only 350Mbps. Imagine customer using 2 x 1Gbps and the router throughput required 3Gbps, the bottleneck at BPL-210.
Hi Steiven,
As of right now the max throughput for the Balance 210 is 350Mbps. This might change in further hardware revisions. If you are looking to achieve higher speeds to take advantage of your ISPs upgrade I have pasted a link to the Balance Spec Sheet below:
The first device that supports 1Gbps speeds is the Balance 305.
