I can’t seem to find “Bonjour Forwarding Settings” on our Balance One that was upgraded to firmware 8.4. I still see it on our other Balance One that is still on firmware 8.2.
The two devices are connected via a PepVPN tunnel.
How do I get Bonjour Forwarding Settings working again on the 8.4 device??
@Phillip_Glau4279 ,
I’m not sure whether the issue that you mentioned are related to the old firmware but I have quick check my Balance One device which is in firmware 8.4.1 and I do see the “Bonjour Forwarding Settings” are available
Suggest that you can upgrade your device using the latest firmware and if you still see the issue, please create a ticket for support team to check.
