I’m looking to replace my current router for the 5G and SmartFusion capabilities.
But, a critical need is the ability to selectively route some traffic through a vpn, and leave the rest untouched.
Example: We live in Country B, but frequently use websites in Country A. So we want those websites to always route through the VPN, and leave local traffic local.
Does the peplink support this? (we use an OpenVPN compliant vpn)
my current router that does this is: GL.iNet GL-MT6000
I would recommend doing this via IC2 where you can create outbound rules based on domain or even region. When you do this you can set your algorithm to be Enforced (aka, required) or Priority to achieve your goal.
THANKS everyone. I just setup my new B One 5G, and the outbound rules work perfect stated. Did find out I had to buy the OpenVPN WAN client license, but that was fine with me.
