Doing some research on using 2 cell cards in a hd2 max mini lte of the same provider to improve signal at a particular location and I came across a post claiming:
The problem is that the cells on the tower see the SpeedFusion VPN tunnel as one data session and thus give both SIM-cards 50% of the bandwidth it would normally give to one SIM-card, in this case the tower seems to handle it a bit differently.
So adding multiple SIM-cards of the same provider without any custom settings will not/barely give you benefit.
The post had many deleted posts on it and I was trying to determine if this was accurate or not, because If its not going to help I obviously do not want to do it.
