Bolton Technical Long Ranger Antenna 2021 Parabolic antenna
Has anyone switched from yagi antennas to a Bolton Technical Long Ranger Antenna 2021 Parabolic antenna? (I suppose you would need two of the bolton parabolic for LTE-A?)
https://www.amazon.com/Bolton-Technical-Ranger-Antenna-Parabolic/dp/B08FBN5LJ7/ref=sr_1_3?dchild=1&keywords=parabolic+4g+lte&qid=1631506532&sr=8-3
Not personally.
The issue with very high gain directional antennas like this is the narrow beamwidth.
10° is narrow enough to make it potentially very difficult to acquire a connection at any distance.
YAGI style antennas are normally more like 50° beam width I think and even then they can be a pig to get alignment right.
Would be interesting to do a comparison though for sure.
