Hi guys,
You can currently set Outbound policies by MAC address to manually choose a LB algorithm but not block the traffic altogether. The reason it has to be by MAC and not IP address is that the IP can easily be changed due to DHCP release or manually assigning a different one. Being able to block a specific device is invaluable.
A workaround is to “Enforce” the traffic over an unused WAN connection but that is no good if all WAN connections are in use.
