I have a T Mobile SIM in the cellular 1 slot and the green light for cellular 1 blinks repeatedly. I switched the T-Mobile cellular 1 SIM to the cellular 2 slot and cellular 2 SIM (Verizon) to the cellular 1 slot and the green light for cellular 2 blinks repeatedly. Is this T Mobile issue or do I have another problem?
What is not working? Do you see an error when you login to the admin page?
Sounds like you have a Max Transit Cat-18 device.
This model for some reason does not work with T-Mobile. I tried 4 different T-Mobile post-paid SIM cards in the last month on the device, and none of them worked. These cards were pulled from working devices and then reinserted into other devices and all worked without issue except for the Cat-18 model.
There are a bunch of threads in the forum with the same issue (https://forum.peplink.com/t/max-transit-cat-18-not-working-on-t-mobile ), and I do not believe it has been resolved at all yet.
Link correction for @Cable17 post.
Happy to Help,
Marcus ![]()
