peplink 210 is supports VLAN this one than how config it.
Go to “Network > Interfaces > LAN”, click the question mark next to “LAN Settings”. You can see the link to enable VLAN feature.
That’s great this means that it can one interface on multi V Lan .second question In BL210 & 310 4 port Lan can i set Lan 1 multi V Lan & Lan 2 multi V Lan…
The Peplink only supports one untagged VLAN so each port cannot be set individually. Multiple vlans are supported by 802.1q tagging. You can connect the Balance to another switch trunking port mode and set individual ports on the external switch.
-Jonan
