Bittorrent block on 380?
#1
Just wondering if it is there.
I see that the Peplink 380 recognizes it in active sessions, but any attempts to block it at the source tcp/udp ports won’t cut it.
#2
is there a solution to block torrents on peplink380
#3
Hi Cecil-Ron_Meyer:
Under Network > Firewall > Content Blocking > Web Blocking, you do have the ability to screen out categories of traffic or add in custom domains to the Customized Domain section (see screenshot). As long as the unit is on current firmware you should be able to have access. Hope this helps!
Jason
The Peplink Team
Block torrent on pep link 380
#4
Thanks Jason…
Fist time working on a Peplink.
And work like a charm…
Thanks you and have a great day…
Peace
