Now i use persistence algorithm for outbound balance policy for all protocols, because i use many apps for live video-streaming (NOT youtube, but special iOS apps).
I have seen that in active sessions, router recognize bit-torrent links, but i cant find a bit-torrent protocol type in outbound routing policy.
Also, I want to understand, how to route bit-torrents over all WANs and keep the persistence for http, ftp, and video streaming.
Yes, the system can recognize it. Anyway, we support layer 3 and layer 4 load balance only at the moment. You may configure Outbound Policy as below. In normal situation, bit torrent should use higher port numbers if those ports are not being blocked.
HTTP
Algorithm = Persistence
FTP
Video Streaming (please ensure you know the port numbers)
I see that all outgoing connections are made fro port 63211 with UDP protocol.
Just imagine that I have many PCs in LAN, with random ip, how could I make rule for outgoing policy to route all outgoing connections from Protocol UDD, random IP, Random destination IP, with source port 63211 to route thru specific WAN?
Thank you for corresponding via PM to provide additional information related to this. As we had discussed, please open a support ticket to better allow us to assist.
