Bind firewall rule to WAN interface
#1
Hi
I would like to know if we can bind some firewall rule to certain WAN and some other rules to other WAN?
For example, I have 3 WAN connections.
WAN 1. WiFi
WAN 2. 3G/LTE
WAN 3. Satellite
The system is configured to use WAN 1 as first priority , WAN 2 as second priority and WAN 3 as third priority
If WAN 1 is active, nothing should be blocked
If WAN 2 is active, only video streaming and P2P should be blocked
If WAN 3 is active, everything should be blocked except port 25 and 110 to a single destination public IP
All computers are connected by LAN, all computers are in the same network/subnet
All user must not required to login (no captive portal).
every computer connected must be subjected to these rules, no exception.
Is this scenario possible with Peplink product?
#2
You would have to build several outbound policy rules, but yes - it is possible to do.
#3
You might try the Outbound Rules as discussed in the post below:
