BGP import and export filtering
Currently in BGP under both Route Import and Route Export I can either accept or reject specific networks, but I can’t do both at the same time. I’d like to see a feature where both are possible.
I don’t see the point, the current process means you can accept only a select number of prefixes, rejecting the rest, or you can reject specific prefixes accepting the rest.
I didn’t have a firm grasp of the current process. If that is the case then it is already working as intended and this feature request can be closed.
