Does anyone have a suggestion for isolating 2 reolink security cams on my Surf Soho Mark 3.
They seem very nosy trying to look at everything in the network instead of just doing their job of providing info to me.
Any others with this experience I would appreciate some help.
Chris
Do both for iot devices, vlan and seperate ssid.
Is there an NVR on the LAN for it as well to save recordings? if so, you might have to fiddle with internal firewall rules if you segregate out to a vlan.
if the app can stream via cloud direct then you might not have to but I presume your notifications and/or live videos will lag a little.
Thanks Jonathan, Is there instructions somewhere for setting up VLans.
I recommend going to:
Check out firmware manual for your device as well as software primer , excellent resources.
Let me know if you have questions after you review.
For VLAN setup, you might also see this
