Hello,I run a small business that I would like to block skype for part of the day for my employees via my peplink. Any suggestions?
It is almost impossible to block Skype traffic at the router level, this is because it uses various protocols and random ports - even 80 and 443.
If you have control over the PC’s on the network you are best off removing the application altogether. You could also use Windows firewall and block access to skype.exe
