Hello all,
This is the first Peplink device I have used and I am loving it so far!
I have 2 76Mbps WAN’s and I was wondering what would be the best outbound policy to setup for balancing load between the 2 WAN’s?
Hello all,
The default rule out of the box checks for latency. If outbound sessions are not being distributed evenly you can use the weighted balance algorithm and configure this manually with a ratio.
Thank you - i shall set up the weighed balance if needed.
