Bandwidth usage warning
When configured the Bandwidth usage waring a warning is send at 75% and 95%.
It would be nice if a warning would be send at 50%
Thanks in advance.
A good idea. When I need a 50% notification today I just set the bandwidth limit to around 2/3s of actual (or 66.7% of actual to be precise) so the 75% notification is triggered at the 50% mark…
Great idea, would also like to see an option to fill in the numbers not the %.
If you have like 50GB set an alarm at 20GB and 40GB.
Although you could theoratically get more percentage done via IC2 Organization at the Pooled sims:
You can filter this either on IMSI or ICCID.
