Ballance settings for router to router connections
I could use guidance and considerations for proper setting when connecting a
balance 20 to A Main balance Two. the infostructure is controlled by a balance Two and works fine . But our sales team have demo systems that is controlled buy a balance 20 that works fine on its own when it makes a direct connection to the modem. my problem is some time the salespeople need to demo with out modem access , there only ethernet connection for the balance 20’s WAN input is a Lan connection from the balance Two the operation is very intermittent and unreliable not all the balance 20’s clients can connect out to the internet
Hello Com,
Would suggest to check if networks on these devices do no overlap (overlapping networks could result in IP addresses conflict and unstable connection). Networks are located on the device GUI under Network → Network Settings section. On most Peplink devices default network is 192.168.50.1/24 and if your both devices does have the same networks issues may occur when balancer20 WAN is connected to B-Two LAN. If this is the case then I would suggest to change b-20 network to some different (example: 192.168.55.1/24) and re-check if the issue persists.
Regards,
Laurynas
