Hi, all.
Is there a way to set QoS on the BalanceOne via SSID? I have 2 SSID networks and I want to limit the bandwidth on one of the networks but dont see that it is really possible?
Thanks!
Hi, all.
Thanks!
Hello RobbieF8,
You can use the QoS Bandwidth Control. You can do this by setting the VLAN to a group under QoS > User Groups. After you have the group defined you can go to QoS > Bandwidth Controls and define the bandwidth to each user in that group (Staff/Guest).
