I seam to be having some kind of streaming issues with the Balance50. Trying to run streaming through the Balance50 after about 5 min. in the stream stutters and acts like it is out of band width. If I unplug the Balance50 and run one DSL line to the device it is fine but the issue always pops up when the Balance50 is in the mix.
I set application priority for streaming to HIGH and it shows the CPU load is only at generally 20%.
Any suggestions for optimizing the Balance50?
Thank you,
Matt
