Lost my post due to 500 bad attempt at rewrite.
Trying to setup another VLAN but can not communicate across boundaries. I tired to change the AP to use 192.168.1.2/24 but could not connect to it for some reason- Will keep trying to get a known good device on the 1.2 subnet and confirm that it is not the device. I think since I’m seeing ‘!H’ in tracenet that it’s not that?
Long-short: Trying to connect LCI CAN<->Ethernet controller to the router. Directly connected via ethernet, moved devices and can lines around to work that. Other CAN devices are still operating as expected, so do not expected device to be non-functional in anyway.
➜ ~ ifconfig en0
en0: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
options=400<CHANNEL_IO>
ether 88:66:5a:1c:89:2a
inet 192.168.50.101 netmask 0xffffff00 broadcast 192.168.50.255
media: autoselect
status: active
➜ ~ curl http://192.168.1.4:8080/rest/things/
curl: (7) Failed to connect to 192.168.1.4 port 8080: Network is unreachable
➜ ~ traceroute 192.168.1.4
traceroute to 192.168.1.4 (192.168.1.4), 128 hops max, 52 byte packets
1 balance-9867 (192.168.50.1) 5.390 ms 3.042 ms 3.869 ms
2 balance-9867 (192.168.50.1) 3076.091 ms !H 3004.095 ms !H 3006.996 ms !H
➜ ~ traceroute 192.168.1.2
traceroute to 192.168.1.2 (192.168.1.2), 128 hops max, 52 byte packets
1 192.168.1.2 (192.168.1.2) 4.416 ms 2.990 ms 3.560 ms
➜ ~ traceroute 192.168.50.42
traceroute to 192.168.50.42 (192.168.50.42), 128 hops max, 52 byte packets
1 192.168.50.42 (192.168.50.42) 7.750 ms 2.345 ms 2.486 ms
