With regards to this advisory, are routers on firmware older than 8.6.1 GA affected by the EC feature issue? We have a couple of Balance 710 running 8.5.0 and 8.6.0, all capable of (although not enabled) EC.
@Khang_Tran if the EC feature is disabled (the default setting), the router is not vulnerable.
Just to follow up on this question, could you please confirm that routers on the older firmware (8.5.0 & 8.6.0) with EC enabled are also affected? The advisory wasn’t clear if it just impacted EC-enabled on 8.6.1, or if it was present on the previous versions as well. Thanks.
