(1) Ethernet Port
- Balance One comes with 10 Ethernet ports: 2 WAN ports and 8 LAN ports. With an additional WAN Activation License (BPL-ONE-LC-5WAN), both the number of WAN and LAN will become 5, allowing you to utilize more WAN inputs.
- Balance Two is embedded with 2 WAN ports and 4 LAN ports.
(2) Throughput
- Balance One has a maximum throughput of 600Mbps.
If the WAN Activation License (BPL-ONE-LC-5WAN) is activated, the throughput will then change to 400Mbps. - Balance Two supports 1 Gbps throughput, enabling a gigabit connection.
