I am looking at some options for a campground and am looking for suggestions. This environment will be a low throughput but high user count environment.
I am looking to load balance 3 - 20/1 mbps internet connections for a total of 30/3. This setup will not be using speedfusion.
The network will have about 6 vlans. The guest count could near 500 users but each guest will be throttled to a low throughput at the AP.
I currently use a Balance one in a network similar to this but have only had about 300 users with no issue.
Any suggestions on if the balance one will be undersized or if the 305 will be overkill?
Hello @stefaben6,
The Balance ONE will most likely suite you, though you will need to get the 5WAN Licence so you can use 3 WANs.
We have deployed many Balance ONE and they make a good entry level product, they are managed from InControl2 and several of them have multiple VLANs, security levels and Captive Portals running very smoothly.
Where are you based, may we suggest engaging with your local Peplink Certified Partner
https://www.peplink.com/peplink-certified-partners/
We are based in Australia is that is of any assistance.
Happy to Help
Marcus
Hi @mldowling,
Thanks for your feedback. I am aware of the 5wan license and will be purchasing that as well! I am thinking I will go with a balance one as the 305 seems to be overkill for my needs. Especially on the throughput side of things. I am US based.
Thanks again,
Ben
