I was in the process of setting up my new router and started getting the following error:
An error occurred while reading CGI reply (no response received)
I cannot access the router any more. How should I proceed?
Thank you.
Thank you.
I would attempt a factory reset of the device by holding in the pin reset button for 5-10 seconds (small pin hole located next to the status light). If the reset does not solve the issue, open a support ticket here: http://cs.peplink.com/contact/support/****
