Hi All,
I have a Balance One that I used for a while, until upgrading to a Balance Two earlier this year.
I needed a test router, so logged in with the old details, then did a factory reset from the menu.
After a few minutes, I went to 192.168.32.1 to login using admin/admin; but “Invalid Username or Password.” Then tried the old username and password, still nothing. Locked myself out, waited 5 mins, then tried Chrome and Safari. Still no access.
Pressed and held the factory rest switch for 30s, waiting for the reboot and then tried the same as above with the three browsers… Still nothing.
The unit clearly hates me and is making this personal (nice AI Peplink), but i’m open to suggestions.
Matt
The default address is 192.168.1.1. If you did a reset and are getting a prompt at 192.168.32.1, you must have another device on the network - or you are not completing the reset.
The device must be powered on and booted up to use the physical reset button. You don’t have to be logged into it but be sure its been on for several minutes so you are sure the boot process is complete. Then press the button until you see the device lights go off briefly.
If you did a factory reset and the IP is not 192.168.1.1 then you might have settings in IC2 being pushed down to it.
Do what @Don_Ferrario suggests to be sure (a hardware reset) then disconnect any WAN connections it might have so that it doesn’t get any new config pushed to it when it reboots. Connect a laptop and visiit http://192.168.1.1 and you shoul dbe able to login then.
Good luck!
Thanks @Don_Ferrarioand @MartinLangmaid - it was IC2 and the WAN. All fixed. Thank you for the advice.
(I am a little sad that it wasn’t a new form of Peplink AI messing with me.)
