Hello All ,
Can anyone tell me the current revision of the Balance One (BPL-ONE)?
Hi RobNovello,
The Balance One:
Current hardware revision: 2
Current firmware revision: 6.3.2 Build 2427 (as of 9/16/2016)
The Balance One Core:
Current hardware revision: 1
You can check the latest firmware versioning / builds here.
Select the appropriate category for your device’s product family, then identify the sub-category (Balance, MAX, Surf) and finally the respective model and hardware revision if applicable.
Hover over the “button” for your device and note the URL information associated, it will indicate the most current firmware version and build number respectively.
Example: Balance One:
This is the latest hardware version which supports IEEE 802.11ac.
Hope this help.
