One Core on 8.1.0 build 4943 cannot see the AX at all. Is there firmware for both slated to be released to allow for management of the AX through the One Core?
@danwangba, I have tested with Balance One (firmware 8.1.0 build 4943) + AP One AX (firmware 3.8.0 build 4894) that works fine. The Balance One is able to manage and sync the Wi-Fi settings with the AP One AX.
Topology:
[Balance One | LAN] <===Switch===> [AP One AX]
Can you share your setup or the connectivity between the Balance One Core and AP One AX?
