I am controlling a AP One AC Mini with a Balance One. I am experiencing a problem adding new SSID"s, when I add the SSID in the Balance One AP GUI, the setting does not get pushed out to the AP One, and the new SSID’s are not showing up. Should this happen automatically, or do I need to push the new configuration in some way.
I am running 6.3.0 build 2189 on the Balance One, and 3.5.2 build 1540 on the AP One.
The have been stuck in this state for at least 2 days, all devices are on the same subnet, and I have tested connectivity in both directions, from the router and from the AP’s.
During my troubleshooting, I added a second AP One, and it got the configuration from the Router. I then tested this issue again, by adding a new SSID, and none of the AP’s changed the configuration.
I suspect there is a bug around changing SSID configs, and not a connection issue.
