Good morning:
I have a Balance One Core running 7.0.2 firmware. I set up Admin Security to use only https/443 and to only connect via LAN. I’m also using the default inbound firewall rule with the block ANY still in place. The device is currently configured to use InControl.
I recently performed a port scan and it’s showing both port 80 and port 443 are still open from the WAN side. Is this a bug or am I missing something?
Thanks!
[xxxxxx@xx-xxx-x ~]$ nmap -p 1-65535 -T4 -A -v -Pn xxx.xxx.xxx.xxx
Starting Nmap 6.40 ( http://nmap.org ) at 2018-01-25 09:19 CST
NSE: Loaded 110 scripts for scanning.
NSE: Script Pre-scanning.
Initiating Parallel DNS resolution of 1 host. at 09:19
Completed Parallel DNS resolution of 1 host. at 09:19, 0.00s elapsed
Initiating Connect Scan at 09:19
Scanning mydevice.myisp.com (xxx.xxx.xxx.xxx) [65535 ports]
Discovered open port 443/tcp on xxx.xxx.xxx.xxx
Discovered open port 80/tcp on xxx.xxx.xxx.xxx
Completed Connect Scan at 09:30, 672.28s elapsed (65535 total ports)
Initiating Service scan at 09:30
Scanning 2 services on mydevice.myisp.com (xxx.xxx.xxx.xxx)
Service scan Timing: About 50.00% done; ETC: 09:33 (0:01:41 remaining)
Completed Service scan at 09:32, 141.14s elapsed (2 services on 1 host)
NSE: Script scanning xxx.xxx.xxx.xxx.
Initiating NSE at 09:32
Completed NSE at 09:34, 144.64s elapsed
Nmap scan report for mydevice.myisp.com (xxx.xxx.xxx.xxx)
Host is up (0.00089s latency).
Not shown: 65533 filtered ports
PORT STATE SERVICE VERSION
80/tcp open http?
443/tcp open https?
1 service unrecognized despite returning data. If you know the service/version, please submit the following fingerprint at Nmap Fingerprint Submitter 2.0 :
