I installed it on several routers to try it out, but the bug “Send All Traffic To is grayed out and cannot be set even though SpeedFusionVPN has been built since FW8.3.0, regardless of routers” is not fixed.
You have to define a profile first.
This is a bug that has been present since FW8.3.0.
Even though the connection is established by creating a profile for Balance router or ConnectProtect and SF VPN in WebAdmin on MAX and MBX series, it is grayed out and cannot be configured.
The screenshot says “no vpns defined” so I assume if you had a screenshot with them in the list it is still greyed out?
SpeedFusionVPN is also represented online on the dashboard in ping and speed measurements.
However, Send All Traffic shows “no vpns defined” and is grayed out and cannot be configured.
