Firmware 5.4.9 is available to download right now. Featuring new SpeedFusion functionality and a range of important performance and stability improvements, Firmware 5.4.9 is an essential update to existing Balance and MAX deployments.
Manual Mapping will allow you to specify each of the WANs remote WAN connections within the SpeedFusion profile. You can access this feature by clicking on the ? on WAN Connection Priority
looks interesting when is it going to be available. in the process of rolling a couple of balance 20s with IPSEC. Pepvpn looks like an option for these.
Hi Hootan,
Manual Mapping in SpeedFusion will allow you to connect to specific wan port @ the remote site it’s like enforcing it to connect to this WAN Port firstly and the benefit of it! if the customer needs to connect specific branch to a dedicated WAN port in his Peplink at the Main branch as the 1st or the only connection point to this branch and other WAN’s as Secondary connection, So now you can control the priority of the connection from both sides
