Hi everyone,
I’m running a Peplink Balance 710 on firmware 8.4.1 and have a problem with Bandwidth Control (QoS) that I can’t figure out.
Setup:
WAN: PPPoE, NAT mode
QoS > User Groups: three groups, Manager, Staff and Guest
SpeedFusion disabled
Manager has no bandwidth limit
Staff and Guest are both set to 5 Mbps download and 5 Mbps upload
Groups are defined by IP range and subnet
Problem:
The download limit works as expected: clients in Staff and Guest are capped at about 5 Mbps. However, the upload limit has no effect. Upload speed from a Staff or Guest client is the same as from a Manager client, with no throttling at all.
How I tested:
Speedtest from a client in the Staff group.
What I’ve checked:
The upload field in the group settings is set to 5 Mbps (not 0/unlimited)
Settings saved and applied
Questions:
Is there a known issue with upload limits in User Groups on 8.4.1?
Does the shaper depend on the WAN upload bandwidth being set correctly under the WAN settings?
Is there any limitation with PPPoE WAN that could affect upload shaping?
Any suggestions or similar experiences would be appreciated. I can provide screenshots of the QoS BandWidth Control configuration or a diagnostic report if needed.
Thanks!
