I did make some changes in the wan and lan addresses… does it need a reboot…?
thanks robert
Did you change the device time settings ? if yes, it may affect the device report. Make sure you restart the device as requested after you had changed the device time .
Beside that, may i know the firmware version running for your B580 ? If the device not running latest firmware, would you please arrange to upgrade the device using the latest firmware to isolate any potential old firmware issue ? You can download the latest firmware by using the following link:
If you still having the issue, please open a support ticket here for support team to check.
Yes I think that I did change the time zone. I’ll reboot it.
7.0.2 build 2167
Thanks for response…
Robert
This was a incomplete configuration of the 580…
