Balance 5000 EC - Meet the next generation Enterprise Router
Not Overkill. Just What You Need.
This isn’t about overkill - it’s about pushing performance to the edge. Blazing speeds, 24/7 uptime, and intelligent edge computing ensure your network never skips a beat. Whether you’re powering enterprise operations or mission-critical systems, you need performance without limits.
Meet the Balance 5000 EC - your next-gen enterprise router and powerful aggregation hub . With up to 30Gbps SpeedFusion throughput, lightning-fast interfaces to future-proof your network, expanded built-in storage, and rock-solid resilience, this is the upgrade you’ve been waiting for.
Learn more
Does this “next-gen enterprise router” support ipv6?
