Hi
I have a firewall Connected to PBX.
I want to put between the firewall and the PBX peplink 380 and enable speedfusion with pepwave.
I asked, what ports should I open in Firewall?
david
Hello David,
SpeedFusion uses TCP port 32015 and UDP port 4500 for the establishment of the connections.
This topic by @Erik_deBie will surely help you:
Hi David,
i think it’s a good idea to read this topic: Configuring SpeedFusion behind a firewall
This way you know the ports involved to create a speeedfusion tunnel. You can try to telnet your HQ on 32015 to check if this connection works. You can force a tunnel setup on different ports. They may block udp4500 because this is the standard for ipsec tunnels. If udp4500 is already in use the next higher port will be used.
