Balance 310 5G - Reliable Enterprise Branch Networks. Simplified
Reliable Enterprise Branch Networks. Simplified.
Deploying a traditional enterprise branch network typically requires multiple dedicated devices: a separate router, 5G gateway, and PoE switch.
The Balance 310 5G consolidates these critical network functions into a single hardware platform, maximizing branch uptime while streamlining deployments.
Unified Architecture
Seamless, Automated Failover
Use the internet service that best fits your business, whether it’s fiber, cable, or Starlink. If the connection drops, the built-in 5G automatically takes over to keep critical applications online.
Integrated PoE+ Connectivity
Connect and power access points, IP cameras, and other devices directly through PoE+ output ports. Simplify deployments and streamline device management from a single platform.
More Advantages
Government-Grade Security
Deploy confidently across regulated environments with FIPS 140-3 validated security.
Edge Computing Ready
Process data right where you need it with native Docker support and onboard storage.
Lower Operational Overhead
Reduce deployment complexity and operational costs with a single standardized platform.
Consolidate your infrastructure. Protect your uptime.
Learn more
