I have Peplink Balance 310 5G, I need to know if i can configure 2 different ISP ? I only see 1 WAN port on the device.
Hi…
Looking 3105g and there is no license for second wan or virtual wan on it.
Ahoy There!
We’ve deployed lots of 3105G (and the big brother 310X5G).
It has a USB Port along with option for VLAN WAN (Additional License).
You can purchase the additional VLAN WAN license from any Peplink reseller.
Feel free to reach out on PM if you need to purchase license or get further support.
weird…
Don’t see VLAN WAN here…
Updating… Bpl-310-5g, have usb type 2! (480mbps)
Weird part II.
Looking at 1Gbps Multi-WAN (5 Ports) Router Balance 310 5G - Peplink . It have an option to buy LIC-VWAN.
Very interesting!
We’ve done this lots, so wonder if there’s a regional restriction to this?
Bought both from EU and AU/NZ suppliers, and all have this option turned ON.
Can you please create ticket and provide your device serial number for us to support team to check ?
Hello…
Don’t worry… I do not want to buy Vlan Wan license for this device.
Thank you.
One VLAN WAN is included with any PrimeCare device. So also with the B310-5G. All our B310-5G that came without, got a free VLAN WAN license when upgraded to 8.3.0 FW or above.
What kind of speeds are your ISP’s? The VLAN WAN might be more limited than the physical WAN in terms of speed, but haven’t had a fast connection on the VLAN WAN on the B310-5G before. It is a X86-64 based platform, so the performance hit would be lower than the ARM models.
As people have said, the 310 5G has 1x WAN port, 1x WAN-on-VLAN (provided your primecare licemse is active) and a USB port (so usb ethernet gives you a 100Mb wan).
You can use LIC-VWAN but note that it doesn’t stack with the one included in primecare, so if you want two you need to buy LIC-VWAN2.
Or… get a B One, and synergize it with the 310 and get 2x wan ports from the B One, controlled/configured from the 310 (and still have the wan-on-vlan from primecare on your 310 itself).
