Balance 305 Firewall Access Rules
Hi
I am new to Peplink universe, i got the basic right, but struggling getting access rules to work…
My setup:
Balance 305 at the HQ <-----> Balance 305 at remote location.
I want to make sure some traffic from remote location will be blocked when trying to connect to HQ.
Ex:
HQ Server1 = 192.168.1.2
Remote Client = 192.168.10.20
So what im trying to do here:
On 305 in Remote location.
Network - Firewall - Access Rules
Create new Outbound Firewall Rule
Protocol = Any
Source IP = 192.168.10.20
Destination = 192.168.1.2
Action = Deny
Event logging = Enabled
Save and Apply Changes.
With that rule i would expect trafic to be blocked now…
But its not…
What am i doing wrong?
Thanks :slight_smile:
Hi Carsten,
if you are using a SpeedFusion VPN, then you have to use the internal Firewall roule.
Hi Dennis
From what i can see i dont use Speedfusion vpn.
But just to try it out i created the same rule under inbound, and it made no changes. My trafic is still coming through. :frowning:
/ Carsten
Then I would create an Any to Any Allow Roule, to create an entry in the FIrewall Logs
If you are use 2 internal IP-Adressen you have a VPN between HQ and Remote Client, if not, you will not see the internal IP Address, only an external IP
Hello.
I believe the TCP/IP addresses he used are just to exemplify the environment.
Just resuming…
HQ-305: 192.168.1.2
REMOTE: 192.168.10.20
So… DENY traffic between these devices.
Doing this rule at HQ-305. Running at INCOMING rule. From WAN of 305 to LAN inside of 305.
Thanks for all replys @MarceloBarros and @dennis.hofheinz
It was the internal access rules i needed to use. I just need to flip them. Have made them the other way around :slight_smile:
I found out when i created a permit any any with log enabled.
So im not able to create rules now…
Then i just need to figure out if i really want to create 200+ rules on a peplink, or i want to route the traffic to a real firewall where i might only need 25 rules for the same job.
Thanks again :slight_smile:
Hi Carsten,
sometimes it’s easier to use InControl2 for the Firewall-Roules.
I think Peplink Routers are great routers with integrated Firewall, but it is a router…
A Firewall has also a routing engine, but it is a Firewall…
So for easy jobs you can use the integrated Firewall, if not, use a device that is build for that reason :wink:
BR
Dennis
I agree @dennis.hofheinz
I think that will be my conclusion as well… It was not ment to be a firewall with access list, beside a few rules where any can be used.
/ Carsten
