I have a balance 30 (192.168.1.1) with a br1 on wan1 (192.168.50.1) and another br1 on wan2 (192.168.50.2). From the LAN I can access 192.168.50.1 but not 192.168.50.2. The balance has the out of the box configuration settings and both wan connections are active. Is there something I need to set to be able to access both wan devices from the LAN?
The balance 30 will be confused because both of its WANS have the same subnet (192.168.50.0/24) so it won’t know when to send your traffic to WAN2. Change the BR1 on WAN2 to use a different subnet (like 192.168.51.0/24) and it will all come right.
That did the trick. Many thanks for your help.
