I am trying to port forward public IP address to an inside address. of 192.168.1.95. I cannot access the router that uses that particular public ip. I do have internet access. Firewall off, all ports open. I noticed the WAN 2 port (which is the port that has the block of IP addresses) is constantly reporting “connecting”. I am new to the peplink router. Shouldnt I see the WAN port connected and showing an address? Also when I go to http://whatismyipaddress.com I see the WAN 1 ip address not an address from the block I am trying to work from. Any suggestions? Thanks in advance for the assist.
the ip address i need to use is associated with WAN 2
