Hi. I’m moving my business and need to assure a reliable ethernet.
I want to connect two 100M cable connections and a 3M radio link to a model 30. I don’t need 203M throughput and I know that the 30 can’t provide it.
But some questions:
http://www.peplink.com/balance/tech-spec/ says the throughput will be 100M, but Peplink | Pepwave - Forum says the new hardware is good for 50M. Which one is closer to the real-world throughput?
Will the “too small” balancer give poor results due to dropping packets etc, or will I get a clean, reliable 100M (or whatever the 30 can do) throughput?
Will it more-or-less balance the traffic between multiple links even though a single link could (in theory) handle everything the 30 could pass?
I can afford a 380 if that is what I need, but I don’t have money to burn if the 30 will serve my relatively simple needs.
Thanks in advance,
Martin.
