My Balance 30 LTE firmware 6.1.0 refuses to upgrade to any newer firmware.  It’s out of Warranty, but I thought I still had access to 6.x firmware upgrades (?).
It starts to upgrade, but then goes into limbo and needs a reboot.  I’ve tried different browsers, different computers, mac/pc, http/https, manual and auto, firmware slot 1 and 2.  Tried 6.1.2, 6.3.3 and various others in between.
When uploading manually using Chrome, it locks up at 65% upload.
Am I SOL or is there a cure?
Can you please try to upgrade the B30LTE using the following step:
- Update firmware with the following update - -Note: the device will reboot after upgrade.
http://download.peplink.com/firmware/plb30/fw-b20_30-6.1.1-build2530.bin  ( May take up to 30Minutes )
- Update firmware with the finishing update -
http://download.peplink.com/firmware/plb30/fw-b20_30-6.3.3-build3231.bin
Do keep us posted for the upgrade status.
Thank You
              That worked beautifully!
FWIW, I would have tried installing 6.1.1 first, but it isn’t listed in the firmware archive: http://www.peplink.com/support/downloads/archive/ .
I’m happy to report this fix also restored my ability to use the Peplink Router Utility ios app, which hadn’t been working.
Thanks a million!
