I have a Balance 30 (2nd version) and would like to better understand the throughput.
I know it’s specification has a throughput of 100Mbps, I assume that’s between LAN & WAN?
If I have a pair of devices connected to the LAN ports should I get the full benefit of the 1Gbps connection. If so is this the case even if the 2 devices are on different VLANs?
I was incorrect here, the InterVLAN routing throughput is not at Gigabit speeds. I am checking with the team to get some numbers, but it is probably closer to the 100 Mbps mark.
