Since we installed the firmware 6.2 on Balance 2500, we lost certain capacities that worked perfectly in 6.1.2.
In terms of our connections and our Speedfusion PPTP VPN access, they work perfectly with the new firmware.
We have three entries with WAN ADSL box or fiber.
Before on Balance 2500 the DNS role was his IP address as the primary dns on each our IP devices, since the update we need to put in each of our pc, a different address primary dns, example 8.8.8.8 in primary dns (google ) in order to surf the internet.
We also have a complete radio network infrastructure upstream of a WAN entry.
Before the rules that we had made in the Balance 2500, we received from outside the WAN input, all of our IP communications radio modules and they came to our NTP server IP and our radio modules management server.
Since this update, the rules do not seem to do their part and yet we have not changed anything.
We even take a test if we downgrad to the old firmware (in reboot) we find our features.
But when we switch on firmware 6.2, everything is blocked.:mad:
Do you have an idea of the reason for this behavior?
Is it clear to redo our rules?
We performed a test with the firmware 6.2 on Balance 2500.
I assigned a WAN to OSPF-0, in addition to PEPVPN set automatically.
When I applied, all IP devices communicate again with our time servers and management of IP radio modules.
I stopped there and I removed from the OSPF-0, the WAN entry.
Because I am not sure this is the right solution.
What will happen if I affected all my WAN inputs connected to ADSL and fiber box OSPF 0?
explication sas telecom pour forum.pdf (402 KB)
