Hello All,
I just have a question about using IPSEC VPN. Can I configure a Peplink Balance 210 HW Version 4 to allow a Cisco RV320 to use IPSEC VPN Tunneling. I have a major client of mine that has 2 offices and they are wanting this to happen with out spending more money. I have been trying to read and see if this is possible but I can’t seem to find anything as of yet. Can anyone help with this?
CG
IPsec with Cisco devices should work without issue. When you’re creating the profile on the Balance, just make sure that all of the settings match what you have entered on the Cisco. A setting mismatch is usually what causes issues.
You can find the IPsec settings under Network > VPN > IPsec VPN.
Hello there… So I have setup the IPsec on the Cisco and I have also set it up on the Peplink but I am having no connectivity. Here are some screen shots from both router can someone tell me what I am doing wrong?
CG
From what I can see, your settings look correct. Can you please open a ticket with us here for further troubleshooting?
