Balance 20x Virtual WAN Port
I have a Balance 20x with Firmware 8.3.0 and Promecare contract.
I configure Virtual WAN on LAN port. It connects but not working. Do i need to downgrade firmware?
What is you Network Topology ?
Do you have configured some LAN port with a VLAN corresponding to the VLAN WAN ?
If yes, what is the type protocol needed for your WAN connection ( DHCP, PPPoE, GRE etc… ) ?
Hi
Both Wan1 and Wan2 have static ips (direct connection). I have conection between wan1-wan1 and wan2-wan2. but if i disconect wan1 the conection between sites falsdown.
Yes, Both Wan1 and Wan2 have the Vlan there vlan associated, and Wan2(LAN3) have VLAN.
What lan port do you have associated with on the vwan? or do you have a small network switch breaking out the vlans? Can you share pictures of your pepwave vwan config and port config?
Have you created a speed fusion tunnel between both 20X ?
Hi Korantin,
No, I didnt create a speedfusion tunel between both balances. Is that necessary?
I have a sfc relay and client conection but with mobile ports as backup.
If you want reliable site to site vpn between both of your 20X you need to create a speed fusion tunnel that include both WAN, you can do it manually if you don’t use Incontrol2 or by Incontrol2 in the section Speedfusion VPN
Create speedfusion vpn with both WAN1 and WAN2 and works perfect.
Thanks.
