i configured a LAN as WAN but its not working. Using the same configuration on WAN1 is working.
Have you tried firmware beta 8.4 ?
where i can find 8.4 ?
after upgrade to 8.4 it was not working.
but a new option to use BGP routing was there, I uncheck that option and it start working. i wanted to send a image of that option but its not visible anymore
ok so all working after 8.4 upgrade?
