Balance 20x rack mount ears REV-C new design
We redesigned our 20x rack mount bracket last year, but we never got a change to post about it.
Introducing 20x Rev C! This bracket eliminates the Left and Right individual ears, as well as the middle support.
Each side can be used on either side for a strong snug fit.
This took many hours to design and re-design are we are very happy with the results, It’s also stronger then before.
We also design a set with a special antenna pingtail mount!
This will allow you to extend the wifi when mounting them front facing.
You can also extend the cellular and rear mount it with the ports facing forward.
20xFrontMount-RackBracket-Extend-Wifi
20xRearMount-RackBracket-ExtendCellular
We have these for sale, and have sent them around the world.
PM me or send or send an e-mail to [email protected] if your interested.
Cost is $29 per set + shipping.
For reference the original post was here:
cool!!
Nice work !
Looks really good - and very useful.
Nice! I was thinking of making one up using a flat shelf and holding down using the wall mount holes on the bottom.
cool design. have been looking for brackets for the B20x. definitely would like to order some. will be sending you an email
